The Never Ending Belt Squeal.
had the same problem mine turned out to be the alternator, changed that and it was all good.
mine only made noise when the car was on idle, i changed everything possible and that was the problem. give it a shot might be that.
i had the same problem, replaced both of my belts..still squeaked, then got an UD pulley with new belts and still squeaked, it turned out to be my ac pulley, so i just cut the belt free and havent heard the noise since
i had the exacnt same problem. My belt was worn out so i replaced it along with the a/c belt and 300 miles or so later the very loud almost a chirping squeak came back. So then i replaced the idler pulley and also replaced my alternator and it stopped for like 15 miles. So then I said ok ill cut off my a/c belt and it still squeaked after that. Finally I took it to a local mechanic who we have done alot of business with and he said my crank pulley had a wobble to it and he thinks thats what caused the squeak. So i replaced that with a slp underdrive pulley and the belts along with a new a/c belt and 2000 miles later no squeaks
but I would definetly check out every other pulley have someone take a look at it. Also all the belt dressing does it make things way way worse it never helps maybe for a few mins but in the end it will always get worse
goodluck I know how you feel it sucks when ur driving down the road and its squeaking away
goodluck and check that crank pulley pulley
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
