oil filler neck.. how the hell do you remove it?
valve cover is off.. im looking at it from the inside... now... there is a little tab in there that is flush with the inside... if you twist the neck to take it out.. the tab bends inward so you can not remove the neck... its like i need to fit a very thin, curved piece of metal in there to push the tab up, but i can get a damn thing in there
anyone esle?
anyone esle?
Originally Posted by warp10
You have to first remove the bolt holding it to the head and then just pull. I had to wiggle mine out while pulling.
Just buy a new one.
Put the oil neck in a vise, then turn the valve cover counter clockwise, look at how it locks into place to make sure it's counter clockwise. They pretty much lock in place when there installed. I doubt you can do it by hand or with pliers, I had to use a vice when I took mine out.
You might break the tabs when you try and remove it, that's why I said to buy a new one. That's what I did when I had my valvecovers powdercoated, the neck is under $10.
it removes the same as the oil cap just i havent seen anybody take it off with breaking it. they are cheap so if you cant get it off buy a new one. i have a mobile one cap it came off a brand new vette.
How ro remove oil filler neck
I developed a way.. you carefully thread a small safety wire underneath the tab, pull the tab up and twist the neck out. No breakage, but definitely like building a ship in a bottle. You need patience.
To remove the fill neck you'll turn it counterclockwise 180 degrees and pull.
It was actually fairly simple ...
It took me hours and gave me fits, but, here is how to do it. There are two tabs at opposite poles. Gently bend the tabs outwards (with a small screwdriver) as you push up on that side of the locking mechanism. You will work the locking mechanism above the ridges and up the tracks. After you get past the two first ridges, you can simply remove the neck by twisting counterclockwise. Seating the assembly on the new valve cover is no picnic either. This is one weird design. No words.
I had fits with this
