Whose horn doesn't work when they want it to?
Ok, so the part that has a spring on it, how does it fasten or does it just sit down in the hole? I replaced the steering wheel with a wheel that was in better shape, now the horn doesn't work. Help please!?
-SS
-SS
Save the manuals!
The black pins on the sleeve with the horn wire lock in to a catch in the white sleeve inside the column. This catch brakes easy, especially if the wire is pulled out of the socket and not twisted out. If the sleeve won't catch, you'll need to replace the turn signal cam, which has a new socket molded in to it.
Save the manuals!
https://ls1tech.com/forums/general-m...ot-spring.html
