Sponsored by: CARiD
Catch can or LS6 Conversion?
Old May 4, 2007 | 09:56 AM
VetteMan's Avatar
Default Catch can or LS6 Conversion?
How good of a patch is the Catch can because the place I take my car too said that they could do it for around 500ish, thats including the kit. Its a great place but I am not sure if I should bother getting the Ls6 conversion now that I only drive my car 2 days a week compared to 7 days which I was doing. I am burning about 1.5 qts every 2k miles. How much will the catch can help? Its only 40 bucks and easy to install...
Old May 4, 2007 | 11:49 AM
Formula413's Avatar
$500 to install a catch can??? I did mine for about $25 in parts and installed it in under an hour. It's been working great so far, it traps quite a bit of oil. I had similar oil consumption to you before the catch can, I will have to wait a while to see how much it has been fixed, there might be other sources of oil consumption too.
Old May 4, 2007 | 11:56 AM
VetteMan's Avatar
No 500 to do the Ls6 Conversion...
VetteMan's Avatar
I know catch can wont fix oil consumption but since I wont be driving as much do you think it would just be better to go with a catch can?
Old May 4, 2007 | 07:36 PM
Formula413's Avatar
Well, a catch can isn't exactly a performance mod. An LS6 intake is. Two totally different things. If you want to do the intake do it. As for the catch can, why not? It's cheap and easy, and keeps oil out of the intake. Oil mixing with the gas will lower the octane number, which doesn't help performance at all. The catch can won't really stop oil consumption, since the oil caught in it is contaminated and shouldn't be re-used. But at least this oil isn't getting into the intake anymore.
Old May 4, 2007 | 08:02 PM
Shallow Bay's Avatar
He's talking about the LS6 PCV conversion and not the LS6 intake manifold. To the original poster, why not tackle the install yourself. It's relatively easy to do and it will save you around $435. The link below will provide you with everything you will need.
http://www.ls1howto.com/index.php?article=18
Old May 4, 2007 | 09:33 PM
Formula413's Avatar
Oh, now I get it...I had never heard of this mod before. I wonder if there is something similar that could be done to an LT1? After reading that writeup, I have to say that if I had an LS1 I would probably just do the catch can instead, that seems like a lot of work. Obviously it is a better solution than a catch can is though.
Old May 6, 2007 | 03:13 PM
INMY01TA's Avatar
Fwiw, I did the LS6 valley cover about 3 or 4 years ago. Helped nothing. It let just as much oil in through the PCV as before. Running a catch can now and it stays bone dry.
