Sponsored by: CARiD
driver side window fixed :)
Old May 5, 2007 | 09:02 PM
GXPPOWER's Avatar
Default driver side window fixed :)
http://shbox.com/page/windowmotor15.html
i used that guys page. everytihng is identical between his lt1 and my ls1.
i bought the new motor from Advante auto for 50 bucks. took me about 1 1/2 hours. mainly because i wanted to make sure and lube it good so the motor will last.
i will say when you do this. Do wear protective glove/goggle and some kind of dust mask. because the door is made out of very brittle fiberglass and once oyu start drilling it goes everywhere.
but i am happy i can now put my top back down. and more importantly go through drivethroughs!!!!!!
Old May 6, 2007 | 04:22 AM
BayAreaSS's Avatar
Soon i will need to replace both motors how hard was it?
I just looked over that page and it looks fairly simple
Old May 6, 2007 | 12:31 PM
michaelxx16's Avatar
i just did mine about two days ago, easy as cake, hardest part was i did it all alone and it was like 10pm and was using a cheap lightsource and had trouble lining up the holes to put the nuts/bolts on to hold the new motor in place, but its cake other than that. just picked up my nuts/bolts from lowes (used a motor i had in another door that worked fine) hated having to stand outside my car at drivethroughs, embarassing as hell lol
good luck w/ the install
Old May 7, 2007 | 01:55 AM
BayAreaSS's Avatar
Thanks......It doesnt seem to hard at all.
i was going to find a shop to do but i will save that money for mods and do the install myself.
Old May 7, 2007 | 10:11 PM
autotrix's Avatar
Closed ex-Sponsor Account
Check us out!
Old May 7, 2007 | 10:48 PM
ONEBADASSWS6's Avatar
Originally Posted by autotrix
Check us out!
Looks good.
How hard it your kit to install?? What must be taken apart??
Old May 8, 2007 | 01:18 AM
BayAreaSS's Avatar
Check us out!
i've seen the passenger side window fix and wouldnt mine buying.......but are you guys going to make a kit for the driver side?
Old May 8, 2007 | 02:36 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
