Sponsored by: CARiD
self-maintenance question
Old Jun 6, 2007 | 05:36 PM
5PONT7's Avatar
Default self-maintenance question
so other than changing my oil every 3k miles and filters now and then, is there any other kinda of service i should be doing between like 60k timing belt and 100k AC flush?
Old Jun 6, 2007 | 05:39 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Timing belt? On an LS1? You must be referring to your daily driver Civic I'm guessing.
And why would you 'flush' the AC system?
Old Jun 6, 2007 | 05:42 PM
5PONT7's Avatar
i just figured you had to do that at around 100,000 the book says you do. But anyway what should i be doing other than all that
Old Jun 6, 2007 | 05:50 PM
davered00ss's Avatar
Moderator
I would not worry about the timming chain. Change the fuel filter, spark plugs & wires. Flush & refill the coolant with Dexcool.
Old Jun 6, 2007 | 05:56 PM
sunsetta's Avatar
It's also a good idea to flush the brake system and cluch system (If you have a manual transmission) since with time, brake fluid attracts moisture and turns to mud then starts corroding components. Pressure bleeding is by far the best way to do this.
Old Jun 6, 2007 | 06:03 PM
Quickin's Avatar
Not really. Might wanna do the spark plugs every 25,000, its easy, cheap and there ain't no way on gods green earth they last anyway near 100,000 miles with any kind of efficiency left in them. Have fun driving.
Old Jun 6, 2007 | 06:06 PM
5PONT7's Avatar
thanks for all of that, and I was just worried cause it seemed like doing an oil filter and change every 3k miles was not enough idk i guess i dont have as much faith in engines. But i mean i got 36,000 miles right now and im gona change the plugs at 40k i think but i really don't know what else to do till around 60 and 100k besides tire rotations and inspecting things every now and then
Old Jun 6, 2007 | 06:44 PM
bad6as's Avatar
imo every fluid in the car should be changed
oil
trans
rear
coolant
power steering
clutch
brake
blinker
and so on
Old Jun 6, 2007 | 07:54 PM
5PONT7's Avatar
yeah but how often should you do the stuff other than oil?
Old Jun 6, 2007 | 08:31 PM
JonB's Avatar
Oil I go every 4k synthetic
Tranny/rear end 20-30,000 depending on driving
Radiator/power steering 50,000
brakes 50,000
clutch 25,000
Plugs/wires 25-30,000
Air/fuel filter 10-15,000
This is just a good ballpark but honeslty i've only put 30k on my car and have changed every fluid in my car atleast twice.
Old Jun 6, 2007 | 08:36 PM
EVILWS6's Avatar
oil
trans
rear
coolant
power steering
clutch
brake
blinker and so on
It's hard to make a turn without that.
Old Jun 7, 2007 | 02:39 AM
SpaZMaN's Avatar
make sure its DOT fluid.
Old Jun 7, 2007 | 04:11 PM
5PONT7's Avatar
sweet thanks for all the help guys, now all i need to do is make up my mind on Headers ha
Old Jun 7, 2007 | 04:54 PM
bad6as's Avatar
well i have the same cat back as you and i went with edelbrock long tubes and their ory there 1 3/4 stepped to 1 7/8 and teh collector is 3.5" and they fit very very well, do a search and you will find some other reviews on them as well and here are some vids of mine
http://videos.streetfire.net/video/...8f600df8926.htm
http://videos.streetfire.net/video/...5b8c7619d0f.htm
Old Jun 7, 2007 | 05:50 PM
Viper's Avatar
Brakes depends on what you do with the car. I autox so I change it out every year, same with PS fluid (turkey baster anyway). Same with clutch, racing is hard in the fluid. Plugs are every 10-15K for me, air filter when it looks dirty (twice a year?). I've changed the rear fluid 3 times in 55K and tranny fluid twice. Oil is obvious. Run your air once every couple of months. Flush the radiator every 50K, I've done mine 3 times but due to new motors...
Old Jun 7, 2007 | 06:50 PM
Spink's Avatar
Lube the chassis. A lot of people who change their own oil neglect this.
Old Jun 7, 2007 | 06:51 PM
5PONT7's Avatar
yeah i don't know how to do that so last time i just took it to the dealer and had them do it
