Sponsored by: CARiD
Down on power + a backfire
Old Jun 13, 2007 | 06:03 PM
Camaro99SS's Avatar
Default Down on power + a backfire
My car has been down on power for awhile now, and i'm not sure what's going on. I know this because my friend's stock 00 M6 T/A keeps up with me from a roll, and I only trapped 106mph in the 1/4 last time at the track.
The car runs and drives normal, good throttle response, no missing, etc. It doesn't matter what rpm I'm at, my friend's T/A runs even with me through all the gears. The only other symptom is the car will backfire loudly (enough to feel the shock) about 5 seconds after letting off from a WOT run. It will do this if I let off and coast in neutral or if I decelerate in any gear.
No codes are thrown, the TR-55 plugs have ~15k gapped at 0.050", and the wires are less than a year old. 7 of the plugs all look the same; not sure about #8 as I didn't pull it when checking for bent pushrods. Only thing I can think of is there's from a cylinder not firing. Any ideas? thanks
Jason
Old Jun 13, 2007 | 06:15 PM
vaticano's Avatar
just a guess maybe to much fuel mine used to backfire like that until i got the injectors dialed in
Camaro99SS's Avatar
I fogot to mention the car does blow out some black smoke at WOT. In the current tune, the car registered 12.8-12.9 air/fuel on the dyno the whole pull about 1.5 years ago.
Jason
Old Jun 13, 2007 | 06:53 PM
Viper's Avatar
For $12.00, try new plugs as 15K on TR55's is a lot.
Old Jun 13, 2007 | 07:01 PM
98SS1LWEE's Avatar
you have cats?
Old Jun 13, 2007 | 07:39 PM
Camaro99SS's Avatar
No I don't have cats or any smog equipment. I'm also going to try fresh plugs and gap them at .060".
Jason
Old Jun 26, 2007 | 03:47 PM
Camaro99SS's Avatar
Well I put new plugs in this past Sunday (TR-55's @ 0.060") and broke the coolant temp sensor by plug #1. I put a new Delco unit in, and now I have another issue. The car seems to run fine part throttle (haven't gone WOT yet), but the guage doesn't work, the fans run all the time, and I'm throwing code P0118, high voltage.
Another interesting thing is that the car would never start with the original sensor unplugged, but with this new sensor, the car runs regardless. I verified with the dealer I got the correct part, and I even tried another sensor from another parts store. What gives?
Jason
Old Jun 26, 2007 | 04:00 PM
Viper's Avatar
P0118 indicates a bad sensor. I know it sounds weird but either 2 new sensors are bad or the plug wires for it got messed up. Use a voltmeter to see if you are getting a reading. Google P0118 and you'll see what I mean.
