Sponsored by: CARiD
Hesitant ignition
Old Jun 30, 2007 | 11:48 PM
OldeSkool's Avatar
Default Hesitant ignition
2002 SS.. 70,000 miles... up until yesterday I never had any problems with starting the car. Turn the key and it was running.
But now it is acting strange, there is a pause where nothing happens, lights go out, then finally it barely starts.
Today it got even stranger, the lights flickered a bit after the pause and before it started up.
Is the battery finally going out on me?
Old Jul 1, 2007 | 12:15 AM
taintedmeat's Avatar
Check your battery terminals. I had a similar problem this past winter, turned out my positive battery cable had vibrated loose a bit. It would act like it was going to start, then all my lights would go out and it wouldn't turn over or anything. A few seconds later it would work. Went to check the battery and found that I could wiggle the positive cable all over the place. Locked it down and it's been fine ever since.
Old Jul 1, 2007 | 01:13 PM
OldeSkool's Avatar
Gosh.. I dont know why I didn't just check them last night before posting... easier to post than think I guess...
Thanks
Old Jul 1, 2007 | 02:49 PM
OldeSkool's Avatar
Well, I checked the terminals, they're OK.
But now the car wont start at all... just clicks. but the power door locks are slow and the horn sounded like a slow death when i pushed the lock button. I think my battery is done.
Old Jul 1, 2007 | 03:22 PM
At least you checked the terminals before replacing the battery. Always best to start simple....and cheap
Old Jul 1, 2007 | 03:23 PM
staringback05's Avatar
check your starter and the wires to the starter
Old Jul 1, 2007 | 03:33 PM
He said the door locks were slow and the horn sounded like Rosie Odonnell breaking wind after a buffalo wing buffet. More than likely a battery/charging issue.
Old Jul 1, 2007 | 04:07 PM
when you deal with power wires running to different areas, it doesnt matter what it is...i had a burnt starter wire and my car threw maf codes?....when dealing in electrical anything can happen...
Old Jul 1, 2007 | 04:44 PM
OldeSkool's Avatar
Very true. I took an entire IROC camaro apart because the under-hood light wire had a short in it.
Pretty sure my 5 year old battery is to blame though, but I will certainly have it tested before I buy a new one.
