Sponsored by: CARiD
passenger door lock help
Old Jul 18, 2007 | 10:22 AM
KingdingdongSS's Avatar
Default passenger door lock help
ok so my passenger door lock just stopped working on me ... I have to unlock it manually everytime and its annoying ...the last time it did this i investigated it and discovered that it was just sticking ... fixed that problem so i thought thats what it might be this time but nope!! it jsut stopped working.... any suggestions or solutions? thanks
Old Jul 18, 2007 | 10:26 AM
oh yeah i am also having an issue with my hatch latch it takes a few times pushing the hatch open button to actually get it to open ... any help with that would be greatly appreciated too
Old Jul 18, 2007 | 11:01 AM
PureWS6's Avatar
Well the door I don't know much about but I had a problem with the hatch release. I did the fix for 99 and NEWER F-bodys found on install university. Works fine now and the fix was simple.
It is in the Install Documents listed under the Miscellaneous category, named Rear Hatch Release Fix 2 (1999 and Newer)
http://www.installuniversity.com/ins...sity/index.htm
Old Jul 18, 2007 | 11:33 AM
hey thanks a lot man ... ill try that hopefully it will work
Old Jul 18, 2007 | 11:45 AM
rd_ls1_z's Avatar
Check the electrical connection to actuator and make sure it's working. You might need a new one.
Old Jul 18, 2007 | 02:55 PM
ok I'll try that.
Old Jul 18, 2007 | 03:01 PM
rd_ls1_z's Avatar
If you need an actuator, Gm Parts Center.net can get them to you cheaper than the dealership if you want new OEM parts.
Old Jul 19, 2007 | 09:43 AM
thanks a lot guys ... im gonna try some stuff tonight and ill let you know it works or not ... hopefully it will
Old Jul 20, 2007 | 10:29 PM
Nitto98's Avatar
dude... i had exact same problem and i sprayed try flo in the latches and locks (including ignition) and it works great! im a locksmith and the door lock not turning at all means, lube the lock! or your key is gold color and wore out! or worse case somebody fuct your lock with somethin!
