Sponsored by: CARiD
suspension noise?
Old Jul 20, 2007 | 11:40 PM
johnson7454's Avatar
Default suspension noise?
My front driver side strut is making a horrible noise. Only whenever i go over a bump or uneven road. It sounds like when ever you go to sit a old rocking chair and all the wood creaks....best i can do...im going to take off the wheel tomorrow and check things over...what do i need to check for, and can i do it?
Old Jul 21, 2007 | 01:01 AM
99DWPTA's Avatar
check for anything broken i would say. make sure your shock isnt leaking anything make sure all bushings are there etc
Old Jul 21, 2007 | 07:14 PM
i checked everything today and found nothing could this be the shock or maybe a rock that caught in the shock????????
Old Jul 21, 2007 | 09:57 PM
crapyboy750's Avatar
i have the same problem but mines in the passenger rear. But my mechanic said that its the pivot, thats not pivoting like its suppose to but its not gonna hurt your car its just freaking annoying.
Old Jul 22, 2007 | 01:57 PM
Blazingz28's Avatar
Almost every fbody ive been in around 100k miles has a squeaky suspension.. my rear squeaks like a sumbich over speedbumps
Old Jul 22, 2007 | 05:43 PM
z28landon's Avatar
so basically it's not a big deal it's just flat out annoying? Anything I can do to fix the problem?
Old Jul 22, 2007 | 05:45 PM
well mine only has 40,000...it also just went away today.......so i dont know...im still taking it to get checked out.
Old Jul 23, 2007 | 12:44 PM
krayzie7th's Avatar
sounds like you have a bad strut,when your going through bumps it feels like rocks are hitting the bottom of the car right? you can also just sit there and turn or steering wheel right and left all the way if you hear that noise then it is your struts.To fix it just get a new strut and replace it.
Old Jul 23, 2007 | 12:51 PM
1QuikZ's Avatar
my suspension squeeks, moans, groans, etc but just bc its old and in need of replacement(soon).
goodluck
Old Jul 24, 2007 | 09:14 PM
Dal1as's Avatar
Grease your swaybar bushings. I do it every year now. Otherwise they bind and creak.
Old Aug 30, 2007 | 06:28 PM
SSNixon's Avatar
Im pretty sure that's where mine is squeaking from aswell, do you take the sway bar off or no?
Old Aug 31, 2007 | 08:39 PM
fortmyerspolice's Avatar
had the same problem, turned out i was missing a bolt that holds the swaybar, and while i was under there my swaybar bushings were loose, get under the car, make sure everything is tight. When I was under there if i pushed up on the swaybar it would make the noise, since i put a bolt in, never done it again
