Sponsored by: CARiD
Getting some clunking from the rear somewhere
Old Aug 14, 2007 | 04:26 PM
RedRocketZ28's Avatar
Default Getting some clunking from the rear somewhere
Hey all, when I take off in first sometimes I hear a clunking in the rear end somewhere. It also does it going in reverse sometimes. It makes the noise just as the car starts to move. The car drives normal and everything but every once in a while I get this noise. It does not happen that often either. Any things I should check? Thanks
Old Aug 14, 2007 | 04:48 PM
Shamson5.7's Avatar
Check to make sure that the exhaust isnt hitting anywhere.
Check to make sure that one of the swaybar brackets isnt broken.
Check to make sure that the TQ Arm bolts havent backed out or if it might be rubbing somewhere.
All Ive got for now.
Old Aug 14, 2007 | 05:07 PM
Thanks for the help. I will check all of those things.
Old Aug 14, 2007 | 06:31 PM
Gallstaff's Avatar
I've had this same problem on every F-body I've ever owned (on number 3 now) and I've never been able to fix it. This is a pretty common problem, isn't it?
Old Aug 14, 2007 | 08:16 PM
03 BUSA's Avatar
I had a rear upper shock nut come loose before and made that kind of noise.
Old Aug 14, 2007 | 09:03 PM
Hopefully it is nothing.
Old Aug 14, 2007 | 11:54 PM
CULATR's Avatar
hey it could possibly be the trans mount too..... will be a sorta thud sound underneath.
Old Aug 15, 2007 | 12:12 PM
Thanks everyone. I will check those things out. Is it normal to hear a slight thud when shifting gears at slow speeds?
Old Aug 15, 2007 | 08:31 PM
So I checked under the car and nothing seemed loose. The drive shaft did have some play in it when the car was in gear but not much. Could this be causing issues? Would a u-joint cause this sound? What about a trans mount? I am stumped. I just hope it isn't the rear end going or something.
Old Aug 15, 2007 | 11:04 PM
CULATR's Avatar
trans mount does this my buddys 98 t/a did the same thing ....sounds like your prob anyway
Old Aug 16, 2007 | 02:46 PM
68Goatboy's Avatar
every so often my M6 makes a clunking sound from the rear. i think its normal-ish
Old Aug 16, 2007 | 11:08 PM
Alfanut's Avatar
There are several similar posts on this board and others. Seems to be a very common problem. Many people think the answer is to torque the lower control arm bolts to 75 ft lbs. I, too, have the same clunk ... seeming to come from the right rear on low-speed bumps. It actually sounds like the trunk lid is loose or something, which it isn't. I first noticed the problem after having my aftermarket suspension installed. Of course, the dealer says it's normal. I can't find anything loose or hitting, but there has got to be a solution to this somewhere.
Old Aug 17, 2007 | 01:52 AM
Fbodynightmare's Avatar
Default trans mount
Trans mount is the easiest place to start, besides looking under the car
Old Aug 17, 2007 | 04:08 AM
Gun5's Avatar
ya any kind of mount, engine or tranny just replaced a engine one on my DD neon and damn no more big *** clunk and my shifter doesnt move (this wasnt even the tranny mount) id check those first then all the bolts for LCA's Torque arm and such
Old Aug 18, 2007 | 01:18 PM
slvr98camaro's Avatar
i get it too, i just kind of ignore it now
Old Aug 18, 2007 | 10:50 PM
letsrun97z's Avatar
i have that same noise expecially going over a speed bump sideways i was going to take it back to the shop that put my gears in i thought something was loose
Old Aug 22, 2007 | 11:24 AM
zdc590's Avatar
Well, this may seem kinda stupid and i could be horribly wrong. But if its coming from the rear right and it happens when you hit bumps....check your spare tire compartment. The jack/wheel in there could be not secured tightly enough. I know that was making noise in my 91 rs.
