Sponsored by: CARiD
The Blinking SES light
Old Sep 14, 2007 | 07:11 PM
redz_02's Avatar
Default The Blinking SES light
Well, when the car starts it idles and runs fine, but then as I get down the street, maybe a mile or two, all power is lost and it feels like it is missing horribly. I have cleaned the maf to no avail, also unplugged it but throttle response is horrible. Sputters and jerks and so on.
Do you think this can be an 02 problem, I've got extras, does it reed from the o2's in speed density? All plugs and wires checked.
My question is, that it runs with out a problem at first then it craps out. The only way I've been fixing it, is by restarting it.
Any Ideas?
Old Sep 14, 2007 | 07:24 PM
2001NBMZ28's Avatar
Flashing SES is a misfire. Do you know what code(s) it's throwing? Can be a lot of things.
Old Sep 14, 2007 | 07:30 PM
joshp14's Avatar
Could be an O2, could also be plugs, wires, or an intake leak (among others)...but as said above, we need codes stored to help you diagnose further. Also, if you have a way to monitor the misfires to see which cylinders it is, this can be very helpful as well.
Old Sep 14, 2007 | 07:53 PM
redz_02's Avatar
I need to get a scan tool, worried about driving it to autozone, about 8 miles away.
I did remove the air and EGR a while back, 3-4 months ago, but this just recently happened.
Would it be plugs or wires if it always runs fine until 5 minutes after. Guessing when it enters closed loop.
Old Sep 15, 2007 | 10:34 AM
Formula413's Avatar
Probabaly not a closed loop thing I would say. Cars with heated O2 sensors go into closed loop within about a minute of starting up. Maybe a plug wire is going out and when it heats up it creates enough resistance to cause a misfire.
Old Sep 15, 2007 | 05:18 PM
ErikElvis's Avatar
I Had similar probs when my pass side O2 wasnt reading. I could gun it and it would run fine. but any normal driving I had a lot of studdering.
Old Sep 15, 2007 | 06:48 PM
redz_02's Avatar
well time to get dirty just bought some bosch 02's, the stock ones have about 90,000 miles.
Also, it doens't run fine when I gun it, and it is running rich as hell.
Old Sep 25, 2007 | 04:26 PM
redz_02's Avatar
Well, just put some MSD wires on and it still misses. Need to swap the O2's but I have been too busy. Damn, people calling in sick every day, jury duty, and so forth. It does it about a minute into it, then when I kill it and restart it, it is fine again until about a minute later. I also unplugged the MAF and it ran like total ***.
Does it register the O2's if you are in Speed Density on these cars with the MAF unplugged?
Old Sep 26, 2007 | 05:30 PM
redz_02's Avatar
It was the O2's, the extensions were touching the long tubes, guess the heat was screwing up the signal. fixed them and added the Bosch O2's, problem solved.
