Sponsored by: CARiD
Rear end fluid....how often should it be changed?
Old Oct 27, 2007 | 10:03 AM
Greggy's Avatar
torsen gear type....I like torsen better because is lasted longer and the torque put down to both wheels is not reduced with age and wear.
Old Oct 27, 2007 | 05:47 PM
dependonauto's Avatar
I do mine every 12-15,000, oil is cheaper than those gears!
Old Oct 28, 2007 | 10:56 PM
johnnydi's Avatar
Those "powderized metal looking specs" ARE specs of metal. I guess I'll have to add this to my maintenance list like the tranny fluid. I thought it lasted forever. John.
Old Oct 28, 2007 | 11:16 PM
RoDan's Avatar
Originally Posted by Greggy
My recomendations for a hard driven street car:
auburn/eaton clutch cone type: Dino GL5 fluid w/ LSD additive at 15-25k miles
zexel torsen/detroit true-trac helical gear type: Synthetic GL5 no LSD additive 25-50k miles.
For me I would use the lower of the two intervals because it is easy and I can keep an eye on things like low levels, wear, inspection of parts.
I agree, except with the part about not using LSD additive with the zexel, I tried that and had horrible results. Made lots of noise only on turns, it was bad. Drained out the fluid and put in some royal purple (already has the additive in it) noise went away 100%. From now on, I will add the LSD additive or use a lube that contains it already.
