Sponsored by: CARiD
Shock problem?
Old Sep 20, 2007 | 02:39 PM
Marksman's Avatar
Default Shock problem?
I've noticed that the pass. rear side of my car has been sitting about 2/3rds lower than the drivers side lately. What could be causing this?
I 'measure' by comparing the distance between the rear quarter panel and the tire on both sides. Is it just a worn out shock?
Edited because I can't estimate distances
Old Sep 20, 2007 | 04:36 PM
2001NBMZ28's Avatar
Don't know what it is, need to get under there with the suspension loaded and see what's going on, 4-6 inches is quite a lot. Check all the mounting brackets for the LCA, upper and lower PHB, springs, shocks, etc.
Old Sep 20, 2007 | 04:55 PM
GMRL's Avatar
Shock have nothing to do with ride height. Thats the springs job. Check the springs/LCAs for binding or damage. Thats a significant amount, got any pics?
Old Sep 20, 2007 | 04:59 PM
jmm98LS1's Avatar
Couple things here:
-Springs determine ride height, not shocks. All shocks to is provide damping. If your passenger side rear is lower, you may have a spring sagging or possibly out of position in the cup.
-I think 4-6" is a bit of an over-estimation....don't you? You've only got ~3" tops between the tire & fender on a stock height car.
Old Sep 20, 2007 | 08:49 PM
Marksman's Avatar
Alright, sounds like I over estimated, I must have been drunk. I suppose another way to look at it is the pass. side is 2/3 lower than the driver side. I'll get under it tomorrow and take a look.
Thanks for the recommendations, I've been out of the car game for a while...
