Does the Air Dam actually help that much?
I can tell its way cooler after I brought it in for the night in the garage, however it is cold outside tonight..
How can you keep the fans running when you turn off the car?
Even with the key on engine off it will rise.
You should hear the high speed fan kick on, if the car is loud open the hood and let it run and see what happens.
