Question about radiator flush/fill mishap
Took my TA to have the radiator flushed and filled today after phoning the shop yesterday to make sure they had the right coolant and equipment.
Found out after the hoses were connected and Dex Cool went leaking, flying and gushing everywhere (two different times) that the machine had been malfunctioning the day before. Sure would've been nice to have been told that when I called.
I was told to keep an eye on the temp guage for roughly 2 weeks because GM vehicles usually develop an air bubble after being flushed and the level could drop too low. What!? Has anyone else ever heard or experienced this? I was also told the hose(s) didn't feel like it had any pressure in it after the system had been filled. Now the temp guage shows it's running a little warmer than before. I'm going to check the level in the morning just to be safe. Is there anything else I should be concerned about or keep an eye on?
Thanks in advance.
her_02ta
Thanks in advance.
her_02ta
You can run it up to temp with the radiator cap off and then shut off and let cool for several hours - top off as needed and do again until level doesn't drop. Watch it closely as coolant can erupt suddenly when up to operating temp. Oh, run the heater on high when doing this so that the core receives some flow.
