Battery?? Starter?? Who Knows??
It doesn't happen all the time...I noticed it only doesn't want to start good when the car has been sitting for a good amount of time.
any suggestions??
Try turning the key to on so the fuel pump kicks on, but wait a few seconds before turning the key to start. See if that helps, it does on mine.
So, is it okay...to just turn key on and wait a few seconds and then start it.... Does that mean everything is okay or is their a serious problem underlaying?
long sit, has gone to zero. If so a "drooling" injector
may be filling your intake with fuel (at least, one
runner).
Have you tried starting with the pedal floored, this
is "flood clear" mode?
the check valve in the fuel pump could have went bad. hook up a fuel guage and turn on the key, then turn it off and watch too see how fast the pressure drops off
Good Luck
