my ls1 overheats with ac on ?
Overheating is 240* with coolant spewing out of the radiator... Your car sounds fine to me because as I said 210 is not overheating..
If you are that worried about it pick up HTP or EFI Live and a laptop. Then you can drive around and log watch and log every sensor on the car. Or even get an interceptor gauge and monitor the temps and everyhitng that way.
Im a newb at this but i think im having the same simular situation but the only difference is i own a 94 lt1. I also changed my water pump and now my temp is going up and down. Up when im at a stop and down when im driving sometimes it may go up when driving. But anyways my question is what the proper procedure to bleeding out the cooling system o and my themo stat is a 190 deg if that would help
