noob removing alternator
like i said, i have been looking... and i still am... but im in the middle of this right now and stuck
***edit ls1 alternator is diff,guess more complex,seeing what i can find for ya.
https://ls1tech.com/forums/showthrea...tor#post372314
https://ls1tech.com/forums/showthrea...al#post8200676
https://ls1tech.com/forums/showthrea...al#post6026264
https://ls1tech.com/forums/showthrea...or#post4866368
https://ls1tech.com/forums/showthrea...or#post5145248
After the front two bolts, I took off the wire from the back.
The bolt in the back.... I had a shorty ratchet and it seemed to work fine for me after I used the open side of a wrench to loosen it. it is a bit of a pain.
Then after I had all the bolts out, just fight it upwards and out of the brackets. Then let it rest on the sway bar. Then from up under the hood I disconnected the wire coming from the top. (A Hook works nicely to disconnect the connector)
Then just keep maneuvering it out from below (in front of?) the sway bar. I think I had to turn it about 135 degrees or so counterclockwise to get it out.
I then reconnected all the wiring after I had the new alternator mounted in.
Hope that helps!
