Transmission Fluid Change?
http://www.bfranker.badz28.com/fbody/lubeoil.htm
thanks
There's an easier way than trying to squeeze the fluid in from a bottle. Get a long piece of tubing, stick one end in the fill hole (tape it in place), and stick a funnel in the other end. Then you can just stand by the car with the funnel end higher than the fill hole and pour the fluid (slowly) in the funnel - since it seeks it own level it will keep flowing thru the tube.
thanks
