Sponsored by: CARiD
intake gasket
Old Jan 19, 2008 | 03:13 PM
nassaublue's Avatar
Default intake gasket
um i gues i need one of these so um how much are they lol i was told today that is why my car wont idle
Old Jan 20, 2008 | 04:49 PM
tc3's Avatar
tc3
who told you that? to verify, get some starting fluid and during idle spray the base of intake manifold and if you hear idle changing its a leak... gaskets are cheap if thats the problem, check for cracks too...
Old Jan 20, 2008 | 04:51 PM
autotrix's Avatar
Closed ex-Sponsor Account
You could verify this diagnosis by spraying intake/carb cleaner around the intake ports and listen for an RPM change. This doenst always work.
I would guess the set is about 40-60 bones.
Old Jan 20, 2008 | 05:16 PM
tc3's Avatar
tc3
yea... a little more then i would have thought.... alldata says about 80 bucks... part number 12533587
Old Jan 20, 2008 | 05:35 PM
snake charmer's Avatar
sometimes the engine will melt these down where they are of no use . also people who sell intake manifolds remove them or reuse them .
they should not be cost much . try to hit up fast , they are about 40 or use to be . i have seen on some intakes were folks have used the black rtv gasket maker but have not run it myself . folks go to many lenghts to save cost .
though if you have to spend a lot you might be better off buying a used intake and just use the gaskets off of it and then sell it .
Old Jan 20, 2008 | 07:58 PM
nassaublue's Avatar
um its a little gaskets and they are only supose to be 25 bucks i found them on a few sites already but tomarow i am takin my car to get a second opinion before i rip the bitch apartand it is hard to spray sumthing into the intake to change the idle cus as it idles it is constantly changing so that wont really help me much or i would def try it if it is not that then what the heck would you all think it is
Old Jan 21, 2008 | 09:18 AM
sreve's Avatar
the best way is with a scan tool looking at the fuel trims you can find leaks you can not hear.
Old Jan 22, 2008 | 05:50 PM
nassaublue's Avatar
i took it to the motor shop that put my motor in and they san it and did a bunch of stuff my throttle position sensor is out so its like hundred bucks it will be fixed tomarow
