Sponsored by: CARiD
no start
Old Jan 20, 2008 | 09:33 PM
99huggerorangeZ's Avatar
Default no start
hey guys, sorry but i got a non lsx question- my dad has a 96 geo metro with the 1.4l 4cylinder and it starts fine in the warmer weather 32 deg. and up but when it is colder then that i will only crank but wont fire over, it sounds like it wants to but just won't. any ideas? i would greatly appreciate it
Old Jan 21, 2008 | 09:24 AM
anyone
Old Jan 22, 2008 | 09:53 PM
can someone atleast point me in the right direction
Old Jan 22, 2008 | 10:13 PM
staringback05's Avatar
whens the last time you did a basic tune up on it? ie plugs, wires, cap?...what type of oil are you running?...are there any codes?...
Old Jan 22, 2008 | 10:20 PM
just recently changed plugs/wires,cap and rotor. i'm running 5w30 oil and there is a 02 sensor SES light.
Old Jan 22, 2008 | 10:21 PM
z28berryhill's Avatar
o2 sensors are a bitch they can do alot of things to your car...i would try that
Old Jan 22, 2008 | 10:23 PM
i am planning on replacing it for him but i doubt that would have anything to do with it not starting,especially in open loop(cold).
Old Jan 22, 2008 | 10:30 PM
its highly unlikely an o2 will effect the start up if the car is running fine after...
check the degree on the distributor...had a problem with a old ford today and cold starts, ended up being the distributor was advanced 20degrees ...
is the fuel pump also priming when you turn the key back...?
Old Jan 22, 2008 | 10:34 PM
ill have to check the distributor but when i turn the key to the run position the fuel pump does prime
Old Jan 22, 2008 | 10:39 PM
check the fuel filter...
Old Jan 22, 2008 | 10:50 PM
ok i will check that too
