What Motor Oil & Oil Filter are you guy's using?
#161
i just cam from oreillys today and they had a filter display, the kn and mobile 1 filters are the same in side. they also had a fram p8ha cut open wow what a pos, about a third less pleats mostly glue and cardboard,the wix is a really nice filter also. i will try to get a pic of them later have to take a core back.
#162
You my man hit the nail on the head.
Also everybody needs to check out this link.
http://www.knizefamily.net/minimopar...nce.html#bosch
#163
Hmm, I've read that before but I didn't remember AC/STP being rated so low. (Bad memory most likely). At least better than Fram ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I will be switching to Bosch. The 3423 will be what I use if my Autozone has it - it's the xref for the PF59. Amsoil's part is the EAO64 if anyone's interested but that's more than I'm gonna spend and AZ doesn't carry it anyway.
#164
Check out my amsoil prices ( I have a commercial account)
![](http://img.photobucket.com/albums/v426/prostreetcamaro/myprices-1.jpg)
And the proper oil filter for our LS1 cars.
![](http://img.photobucket.com/albums/v426/prostreetcamaro/myprices2.jpg)
#168
No actually my father and I own a small lawn care company so we were able to open a commercial account with amsoil. An amsoil dealer told me I actually get the products cheaper than he can get them. I use it in all of our cars, trucks, race cars and the engines on our commercial mowers. It really is the best oil I have ever used but I personaly wouldnt be buying it if I didnt get such a good deal on it because there are alot of other very good products on the market also. I have to admit I do let friends and family order it through my account.
#169
BTW I miss 75-80!!!!!! Damn you Bill!!!!! Friday nights were a blast!
#171
Check out the amsoil racing oils.
http://www.amsoil.com/storefront/rd30.aspx
"APPLICATIONS
AMSOIL Dominator Synthetic 10W-30 Racing Oil is recommended for high-rpm, high-horsepower, turbo/supercharged, gasoline- or alcohol-burning and nitrous oxide gas-injected applications operated under severe conditions."
My price is $8.55 a quart plus shipping. Let me know if you want some. You can get it at my cost and come pick it up in germantown off of observation drive across from the walmart if you like.
#175
the pp i have in it now has a cst of 10.2 @ 100 the rotella syn. 5x40 has a cst of 15.5 @100 and if i read right gc is 12.1
im looking for a 5w or 0w that has a cst in the lower range of a 40w but is still syn. mobile 1 0w40 seams to fil the bill but i need a oil that wont break down fast
#176
Here is amsoil 5W-40 European 100% synthetic
TYPICAL TECHNICAL PROPERTIES
European Car Formula 100% Synthetic 5W-40 Motor Oil (AFL)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
13.7
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
79.7
Viscosity Index (ASTM D-2270)
177
Viscosity CCS, cP @ °C (ASTM D-5293)
5121 (-30)
Flash Point °C (°F) (ASTM D-92)
230 (446)
Fire Point °C (°F) (ASTM D-92)
246 (474)
Pour Point °C (°F) (ASTM D-97) -42 (-44)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
8.7
Four Ball Wear Test (ASTM D-4172B @ 40 kg, 75°C, 1200 rpm, 1 hr), Scar, mm
0.44
Total Base Number 8.0
HTHS (cP) (ASTM D-4683) 3.7
Here is Amsoil 5W-30 heavy duty 100% synthetic diesel oil. This is an awsome oil. Has a very stout add pack and a TBN of 12.1
TYPICAL TECHNICAL PROPERTIES - Revised as of 6/08
AMSOIL Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil (HDD)
11.4
65.4
170
Cold Crank Simulator Apparent Viscosity @ -30°C, cP (ASTM D-5293)
5271
-50 (-58)
240 (464)
Noack Volatility (DIN 51581) 250°C for 1 hour, % weight loss 7.6
High Temperature/High Shear Viscosity, cP, 150°C, 1.0 x 106 s-1 (ASTM D-4683) 3.4
Four-Ball Wear Test (ASTM D-4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.38
Total Base Number
12.1
#177
still not sure how to read the spec sheets. and what number means what. its a 98 cam only with nitrous, has 102k and is not my dd. less then 5k a year. do you think the ams oil 5w40 would be better for me.
