Sponsored by: CARiD
slow turn signals
Old Feb 17, 2008 | 11:15 AM
THEBRAD's Avatar
Default slow turn signals
i just bought a 99 t/a yester day and i though i had burnt out signal light but they both work, but they only signal like every other second slow as ****. what could be the problem? bad flasher?
Old Feb 17, 2008 | 03:42 PM
Wsteun's Avatar
Are you sure they just blink slow in the first place?
Old Feb 17, 2008 | 05:39 PM
wssix99's Avatar
Save the manuals!
Bad flasher. Its an old mechanical style and does burn out. Inexpensive part - but hard to find.
Its tucked over the side of one of the black supports under the dash after you take off the cover over the bottom of the steering column. The only thing you will be able to see is the backside of the clip holding the flasher and the wires going down the back side of the support. (There are some good posts on the site with pics.)
Old Feb 17, 2008 | 09:05 PM
THEBRAD's Avatar
sweet dude thanks
Old Feb 17, 2008 | 09:10 PM
954mula's Avatar
True, could also be bad bulb socket in rear harness. I had one with the notorious bad ground and flashing varied when I would move it around.
Old Feb 17, 2008 | 09:18 PM
THEBRAD's Avatar
flashing seems to be the same all the time, slow lol
Old Feb 18, 2008 | 02:28 AM
waldershrek's Avatar
My buddy's '99 has really slow flashers too compared to my '01 and all his bulbs work. I'm wondering if they were just made that way......
Old Feb 18, 2008 | 10:27 AM
xterminator's Avatar
i just replaced the flasher on my car and it flashes twice as fast as it used to id say thats your problem
Old Feb 18, 2008 | 10:36 AM
Z Fury's Avatar
Since no one else mentioned it, you could try this...
Old Feb 18, 2008 | 05:00 PM
THEBRAD's Avatar
hahahahahaha! where in the hell did u find that!? thats awesome
Old Feb 19, 2008 | 04:43 PM
954mula's Avatar
http://www.kalecoauto.com/
Old Feb 19, 2008 | 06:49 PM
Dskeet6's Avatar
is there any other gm cars you could grab this part from in the junkyard???
