Sponsored by: CARiD
Problem continues
Old Feb 21, 2008 | 12:00 PM
94T/A5.7LT1's Avatar
Default Problem continues
ok so i though i had the hesitation problem fixed and it was for a little less then a week, but it started doing it again on my yesterday. There is still no SES light that is coming, so i cant tell if its throwing any codes. It only does it when i drive the car some place and i turn it off for about a half hour then start driving it again. Then about after 5 to 10 minutes of driving the hesitation stops and the car drives great. I started changing some stuff when it first started with the cheapest firs, I changed plugs, wires, coil, PCV valve, Fuel filter, Cleaned MAF, Shot deep creep down the manifold, Seafomed the fuel, and most recent was Changed the O2 sensors. I have NO clue as what it could be now. On my next day off and it stops raining im going to check to see if any of my plugs are fouled. Anyone have any other ideas on what to change? Dont got much money now since i had to go buy a new transmission and converter. Is it possible that it could be the tranny or torque converter causing the feeling like it hesitating?
Thanks
Old Feb 21, 2008 | 06:14 PM
Anyone?
Old Feb 21, 2008 | 07:52 PM
LT1PwrdZ's Avatar
is it at full throttle or just putting around?
Old Feb 21, 2008 | 10:09 PM
it does it no matter how much gas i give it. At full throttle is just stumble and stumbles then all of a sudden just kicks in and takes off.
Old Feb 22, 2008 | 12:23 PM
Could a bad EGR valve be causing this? I would like to keep with the cheapest first. I will be picking up a fuel pressure gauge to make sure i getting the right fuel, but where does it hook up to? What type of gauge should i get?
Old Feb 22, 2008 | 04:10 PM
7901 WS6's Avatar
You might be able to rent one from a parts store. and it connects near back of the intake manifold, There is a lil cap to unscrew and connect up the gauge. you should be able to get to from the passenger side.
Old Feb 23, 2008 | 12:50 AM
Alright well today it did it again and this time i left it in gear and let it idled to see what happens. Well it just seem to struggle to stay running and i would go down in rpms and then jump back up back and forth till finaly it just died. when it died the check gauges light came on and it all looked fine but the battery guage was a little in the yellowish low side. But its a brand new optima red top and it only has the problem every once in awhile. Now i did run my MAF without a screen for a couple of weeks and im pretty sure after that is when it started doing this. So it got me thinking that maybe during those couple of weeks that i screwed something up with the MAF, but why would it happen every so often or when it does happen its for like 5 to 10 minutes while driving then its fine? Its really starting to tick me off that i just cant seem to find whats going on and the wallet is getting lighter and lighter. Thanks everyone been help full so far
Old Feb 23, 2008 | 03:05 AM
kw's01z28's Avatar
my 96 ta i had would do the same **** but yeah it was the opti spark i would punch it then it would almost die out then kick in, once you start doing any mods the opti will start screwing up.
