Sponsored by: CARiD
AC drain tube?
Old Feb 22, 2008 | 10:04 AM
badmfkr's Avatar
Default AC drain tube?
anyone have an image of the AC drain tube I think mine maybe cloged.
I get a small puddle of water under the foot brake after a heavy rain.
is there a body plug near the foot brake?
I don't think it's the heater core because I don't smell any coolant.
I rarely use the AC.
I've searched this issuse without a resolution.
Thanks
Old Feb 22, 2008 | 10:47 AM
2001NBMZ28's Avatar
If the drain is clogged usually you'll get condensate water on the passenger side or towards the middle - here's a pic on a LT1 car, ours is similar. http://shbox.com/1/a_c_drain.jpg
Old Feb 22, 2008 | 11:16 AM
_JB_'s Avatar
Its probably not the AC drain. The AC drain will usually leak into the car when you use it, but since you dont use AC I dont believe its your problem.
Old Feb 22, 2008 | 01:31 PM
badmfkr's Avatar
Default water
from my research I come up w/ possiable causes.
1. hood cable gromet. well I covered that with glue it was kindof hard to reach in there so I used alot of glue.
2.heater core leaking. well it only on the driver side.
3.AC drain tube clogged. same as above.
the weather striping looks in good shape.
is there a body plug in this area?
any sugestions would be good.
guess I'll have to crawl under the dash while some sparys water on the windsheild.
Thanks post #2 for image
Old Feb 22, 2008 | 01:43 PM
blkbird's Avatar
could be on of the plugs in the firewall.
Old Feb 22, 2008 | 02:35 PM
badmfkr's Avatar
Default plugs on firewall
please let me know where these plugs on firewall are located.
Thanks
Old Feb 25, 2008 | 11:12 AM
badmfkr's Avatar
Default crawled under car today
I crawled under car today to look for this AC drain tube did'nt see the small plastic box I've read here about but did see a small tube about one inch sicking out of the body right where the pass. cat used to be there's a heat shield for the cat the tube is just above the lower heat shield bolt.
is this the AC drain?
if yes I guess I'll have to fab up a coat hanger to poke at it Da it's tight in there.
Thanks
Old Feb 25, 2008 | 11:14 AM
badmfkr's Avatar
Default AC drain image
AC drain image
Old Feb 25, 2008 | 05:58 PM
blkbird's Avatar
Mine is just a hole at the bottom of the box like the pic from shbox.
Old Oct 10, 2008 | 02:52 PM
rmpitzer's Avatar
This has been driving me nuts for awhile. My car has no drain hose, that I can find. Just a hole like in the shbox pic.
I can't quite make out what the drain hose looks like in the other picture.
I just read this in the Tip of the Month at the back of the November issue of Super Chevy., it talks about wet floors on the drivers side in late model Camaros and Firebirds....
"There is a drain line that is supposed to direct water to the outside of the car. If enough debris enters the vents just forward of the windshield on the outside, it will work it's way down the evaporator case and eventually plug the drain line. It's just a matter of time.
But it's a simple task to remove the blower motor out of the evap case and claen the drain. You don't have to be a plumber to accomplish this and, Drano won't work! If you have a wet floor, look for this quick fix to dry up your F-body."
Has anyone ever tried this by removing the blower motor? I've seen so much mention of a drain tube with our cars....but have seen no evidence of such a thing.
-Rich
Old Sep 14, 2009 | 06:38 PM
greezy's Avatar
just stuck in my screw driver into this hole and got a free shower. and im pretty sure i cigarette butt fell out haha. same as other pics but i put arrows. i was also looking for a hose of some sort. just a random hole
Old Sep 14, 2009 | 11:20 PM
badmfkr's Avatar
Default leak
I have resolved this leak it was the hood cable gromit.
thanks for the image
