help!! plug on top of alternator
Don't forget to disconnect the battery!!!!
yeh.. easy.
it's under the PS pump. you'll need to remove the primary belt, then the alt.
while under there it's a great time to examine the health of the belt and to spin the waterpump by hand.
also, look carefully at the waterpump weep hole.
As stated above, be VERY careful about that red field wire on top of the alternator. It will break VERY easy if you don't support the unit as you adjust it enough to unplug that wire.
