Sponsored by: CARiD
Rear Hatch hinge is driving me nuts!!!!
Old Mar 9, 2008 | 06:29 PM
02T/A-WS6's Avatar
Default Rear Hatch hinge is driving me nuts!!!!
Ok I have searched and didnt find the anyone with the same noise, which amazes the hell out of me. On my 1996 firebird the rear hatch hinge(left one) squeaks like crazy when ever I hit a bump or something. I have tried sprayin(actually soaking) the hinge with wd-40 and had no luck. It squeaked as soon as I left my driveway later that day.
Do I need a new hinge? or will some kinda grease help me out?
Old Mar 9, 2008 | 07:55 PM
Toronto_LT1's Avatar
i have the same goddamn problem.
Old Mar 9, 2008 | 08:47 PM
wssix99's Avatar
Save the manuals!
The only thing WD-40 is good for on a car is loosening rusted bolts. On hinges, it just washes away or picks up dust and gums up.
Try SuperLube with their precision oiler. (Menard's sells them around where I live and you can also google it.) Not exactly sure about the hatch hinges, but GM recommends it for door hinges and it works great. I used it on my doors and the last application has lasted up to 2 years at this point.
Old Mar 9, 2008 | 08:50 PM
02T/A-WS6's Avatar
SuperLube eh? Sounds like a quality name LOL. Never heard of Menards but I will try and track some down because it would be worth it. Thanks
Anybody else have any opinions?
Old Mar 9, 2008 | 08:57 PM
uphigh07's Avatar
i think i will try the superlube also!
Old Mar 10, 2008 | 07:24 AM
RsSean's Avatar
I have the same problem, but I thimk it is the little rubber/plastic bummers that adjust the decklid in the back. Would that mernard stuff work for this to?
Old Mar 10, 2008 | 08:02 AM
wssix99's Avatar
Save the manuals!
No, the SuperLube (yes... alternative uses come to mind...) oil is mainly for heavy metal to metal contact.
If you want to put grease on a rubber/plastic to metal contact point, I'd go with some White Lithium grease. Get the stuff that comes in a spray can - its more useful on the car. The White Lithium spray is also good for lubricating springs, squeaky clutch pedals, hood latches, etc.
Old Mar 10, 2008 | 09:23 AM
01WS6/tamu's Avatar
Replace the hinge. The guide pin that swivels has a teflon like coating when they are new. As it wears it will begin making that noise. My 96 did the same thing. Replaced it and it was good as new.
Old Mar 10, 2008 | 08:26 PM
LowSS's Avatar
Put some lithium grease on the two rubber bump stops, that took care of mine.
Old Mar 10, 2008 | 08:46 PM
1999Transamman's Avatar
White lithium, I went crazy one day on my bird, every hinge, mount, anything that moves, and it helped alot.
Old Mar 10, 2008 | 10:27 PM
02T/A-WS6's Avatar
Well as an update I did a little bit more listening and its actually not the hinge but its the top of the left shock for the hatch. Which is just a little bit from the hinge but I tried some 2 dollar stuff from pepboys and it didnt do the trick but I did see some white lithium grease there too so I will try that too
