Sponsored by: CARiD
Plugs seized or stuck
Old Mar 10, 2008 | 08:32 PM
tee-boy's Avatar
Default Plugs seized or stuck
didn't use anti seize last time I put in tthe NGK TR 55's.
went to pull the number one plug today, and it wouldn't budge. I'm guessing breaker bar will be only way to budge it.
What do you guys think? will I have problems?
Old Mar 10, 2008 | 08:44 PM
1999Transamman's Avatar
get the engine warm, that might help. How much did you torque the plugs last time?
Old Mar 11, 2008 | 09:10 AM
tee-boy's Avatar
I would say hand tight then a quarter turn.
Old Mar 11, 2008 | 09:13 AM
keliente's Avatar
I would use a breaker bar, as gently as possible. And get some anti seize for this time of course.
Old Mar 11, 2008 | 09:16 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Just get something with some extra leverage, and have some band-aids handy for when it breaks loose and your hand inevitably flies into something pointy/sharp. You won't be making that same mistake again.
Old Mar 11, 2008 | 09:45 AM
keliente's Avatar
Old Mar 11, 2008 | 10:51 AM
tee-boy's Avatar
thanks. I'm looking forward to the number 8 plug.
Old Mar 12, 2008 | 07:47 PM
MagnaTransAm0098's Avatar
if you have headers ..maybe even stock not sure tho never did it, # 8 is easy from the bottom.
Old Mar 12, 2008 | 09:10 PM
FreByrd's Avatar
a breaker bar and SLOW on breaking it loose.
jason
Old Mar 12, 2008 | 10:18 PM
BlackDuk98's Avatar
DON'T warm the engine up and then try to break them free. That is one thing that you NEVER do with aluminum heads. When aluminum is heated, you have the potential of pulling the threads and causing major headaches. You soak them down and heat them up when you have steel heads. When the car is hot and off, spray them down and let them soak and cool (overnight is a good amount of time) this gives it time to sink into the threads and start to work. Then use slow, smooth even pressure when loosening. Also, don't "over" anti sieze them. If you do that, when the car heats up, the antisieze gets into a more liquid state, and could run onto the electrode and cause problems. Seen it happen a few times
Old Mar 13, 2008 | 11:05 AM
Redneck02's Avatar
+1 dude dont heat them up and try and work on them. really bad idea. just like blackduk98 said, pull the wires off and then soak them. slow and steady pressure and they will come out. i would use pb blaster. i use that stuff for everything mechanical on the car. good luck!!
Old Mar 13, 2008 | 08:09 PM
FreByrd's Avatar
EXACTLY, on another note when applying anti-sieze try not to get any towards the tip of the plug, like the upper half. Midway and on down and your good to go : )
jason
