Sponsored by: CARiD
Is this the fuel pump?
Old Mar 14, 2008 | 06:40 AM
PonyTamr's Avatar
Default Is this the fuel pump?
Today I was driving and my car decided to start bucking and died on me, I let it sit for a bit, and started it, it started but was very hesitant to accelerate. it dies again about 200 yards away. i start it up, suddenly theres a loud whining noise at idle, i pull out car is still bucking and kicking trying to accelerate and the whining sound still can be heard driving, seems to be coming from the back of the car. This happened before, and only seems to happen on warm days, i thought i had a coil pack going bad untill i heard the whining noise..
does this sound like a fuel pump to you guys? never had to replace one before.
Old Mar 14, 2008 | 06:54 AM
black01_WS6's Avatar
Usually whining from the back is a rear end, but if the car is dying on you I would guess the fuel pump.
Start the car and get out and listen for where it is coming from.
If it is the fuel pump get the racetronics kit for 240 shipped to your door as it is the easiest t use- simplly plug and play,
Old Mar 14, 2008 | 10:32 AM
qwk93ta's Avatar
When mine went out it just made a lot of noise, nothing else.
Old Mar 14, 2008 | 11:37 AM
SparkyJJO's Avatar
I know it involves cutting but the trapdoor method would save you the frustration of dropping the tank.
Old Mar 14, 2008 | 12:20 PM
waldershrek's Avatar
It could be the pump. disconnect the line at the fuel filter and have somebody turn the key to see if it is pumping. If not, then there's your answer. It could also be a really clogged fuel filter too if not the pump.
Old Mar 14, 2008 | 12:44 PM
BlueThunder2's Avatar
Definitely fuel pump related. Either clogged filter, clogged filter on pump, or pump going bad.
Old Mar 14, 2008 | 12:47 PM
RA4926's Avatar
agreed ^^
Old Mar 15, 2008 | 07:04 AM
PonyTamr's Avatar
Fuel filter was changed 2k miles ago, so i doubt its that, but thanks guys, hope it is the fuel pump (not because the money its going to cost, but just so i finally know whats wrong with it, its been an on-going issue that non of the local mechanics found)
Old Mar 15, 2008 | 02:46 PM
BlueZ35th's Avatar
rip the filter off and check it for dirt.. sounds like somebody got bad gas for 3.50/gal
Old Mar 15, 2008 | 02:50 PM
D-Webz's Avatar
Thats exactly how my fuel pump went out. I could hear a whining from the rear end when the car was not in motion and it would start to die after awhile and had not power. My advice would be to hook up a fuel pressure gauge if you havent already. That was the only way that I could convince anyone thats what the problem was.
Old Mar 15, 2008 | 02:56 PM
Blackhawk777's Avatar
Fuel pump. Mine did the EXACT same thing last summer. The racetronix pump is the
Old Mar 16, 2008 | 11:12 AM
PonyTamr's Avatar
Alright, thanks guys, i have it sitting at my buddys shop right now me and him are going to work on it monday
Old Mar 17, 2008 | 09:54 AM
PonyTamr's Avatar
Welp, we started early, and we got the pump out, its shot, car wouldnt even start today, Ordered a new one that should be here tomorrow. hopefully once this goes in my problem will be solved.
Old Mar 18, 2008 | 09:59 PM
PonyTamr's Avatar
Final update, fuel pump is in, car is running strong!, no more rough *** idle, no more stalling at stops haha, well worth the money and time and most of all learning expereince!
Old Mar 18, 2008 | 10:09 PM
SparkyJJO's Avatar
Glad to know it was the problem! Did you drop the tank or use the trap door method?
Old Mar 20, 2008 | 01:40 PM
PonyTamr's Avatar
dropped the tank, to learn how to do it pretty much lol.
