Serious Brake Issue. PLEASE help !!
I went ahead and replaced the front brake pads just to be sure even though they were good, but it didn't fix the problem.
I adjusted the rear drum brakes, thought they weren't grabing and causing the front pads to work too hard to stop the truck and for that reason they slip, but it wasn't the case either.
What do you guys think my problem is. Again, when you push the pedal, you "Almost" hit your head on the front wind shield instead of stoping normally, it grabs QUICK then it SLIPS then it sometimes stop and sometimes doesn't.
Any help will be greatly appreciated, all brake pads/shoes are new.
Thanks very much for your opinion.
Also, I'd like to mention, on the brake pads, the metal piece on the front brake pads was an inch or so off it's actual location on the brake pads, that's the reason I replaced them, I checked the calipers but not sure if any problem's there. The metal piece I'm talking about it the piece that's attached to the brake pad with two clips that hold the pads on the caliper, that piece for some reason wasn't in it's actual location so I replaced them and here I'm having the same exact issue I've had before replacing them.
I really appreciate all your comments/suggestion trying to help me out with this guys.
