Coolant
Old 03-19-2008, 11:49 AM
lilblackZ28's Avatar
Default Coolant
I am putting in a 160 thermostat.I am reading the directions and it says to unscrew the pressure side bleed screw so it doesnt splash on the distributer.The coolant level will drop when screw is open all the way. So will all the coolant in the radiator be lost then?
I pick up the dex-cool 50-50 blend for my car is that right?
Do i need to use anything gasket sealer on the thermosat housing to make it seal?
I am asking because I dont want to do it wrong at all. thanks
Old 03-19-2008, 12:26 PM
sroach20's Avatar
is this on an lt1?
Old 03-19-2008, 01:18 PM
1Loudz28's Avatar
http://www.installuniversity.com/ins...sity/index.htm
all the info youll need for the swap!!
*edit* just saw what you wrote about the distributor...the write up above is for ls1s.
Old 03-19-2008, 01:28 PM
its an LT1...also my friend had a hypertech programmer..its the same year camaro as mine..so there shouldnt be any reason for it not to work right..
Old 03-19-2008, 01:49 PM
lt1 hawk's Avatar
I thought that the hypertechs would not work for two different cars, even same year, because they read the VIN...
Old 03-19-2008, 01:54 PM
sroach20's Avatar
i think they are only year specific. if you remove the program on one you can put it on another in the same year model.
Old 03-19-2008, 03:12 PM
1Loudz28's Avatar
hypertechs are vin # locked to the one vehicle that is tuned by the handheld.
Old 03-19-2008, 03:24 PM
sroach20's Avatar
until you do the restore to factory option. then you can use it on any vehicle of the same year. thats the way it worked on my truck before i knew they were crap.
Old 03-19-2008, 05:36 PM
it tuned onhis car so it wont work in my then unless he goes back 2 factory options
