Sponsored by: CARiD
for those that are running Optima batteries.....
Old Mar 31, 2006 | 12:18 PM
JR HAWK 9's Avatar
Default for those that are running Optima batteries.....
what size are you running? They make both the D75/25 and D34/78 in yellow and red tops. The D75/25 is a bit smaller and will fit with no problems or adaptors from what I have read. The bigger D34/78 is a bit wider and requires a adaptor to correctly mount it to the stock mount.
I just ordered a yellow top D75/35, as I didn't want to take the chance of it not fitting or if it not mounting correctly.
Here's the D75/25 in yellow top:
Here's the D34/78 in yellow top:
Old Mar 31, 2006 | 01:04 PM
2001NBMZ28's Avatar
I just bought a red top 75/35, looks like your first pic - no fitment problems at all.
Old Mar 31, 2006 | 01:08 PM
JR HAWK 9's Avatar
you mean the 75/25??
Red Top 75/25
Old Mar 31, 2006 | 01:24 PM
2001NBMZ28's Avatar
75/35 - Got mine from Sears. Just went to their site and the red top 75/25 pic doesn't have side posts? Maybe the yellow tops are different.
Old Mar 31, 2006 | 01:59 PM
JR HAWK 9's Avatar
hmmmm,
Optima's site doesn't even list a 75/35.....might be a typo..
http://www.optimabatteries.com/publi...cal_specs.html
Old Mar 31, 2006 | 02:11 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I run a 75/35 Red Top here...fit perfect.
Old Mar 31, 2006 | 04:33 PM
OctaneZ28's Avatar
75/25 red top here, perfect fit.
Old Jun 3, 2006 | 12:11 AM
coolformula's Avatar
I got a 75/35 for my firebird about a month ago...now just got a LS1 and got a new red top...went to sears becuase they gave me a 78 ..wrong one..anway we finally after about 30 min figured out that optima changed it. the 75/35 and the 75/25 same thing same ratings..same part # side and top posts..anway its looks like the 75/25 is the newer one mine was made this month....so its brand spanking new....
Old Jun 3, 2006 | 06:28 AM
billyb's Avatar
Default optimas batt.
guys did you know that optima make a cover for their batt, snaps in on top, really looks good !!!
Old Jun 5, 2006 | 12:26 AM
98hardtopZ's Avatar
dont mean to hijack but whats so much better about an optima?
Old Jun 5, 2006 | 04:54 AM
ChevyGoldfinger's Avatar
Well, for openers the Optima is a true sealed battery. You never have to worry about it boiling the water low like Interstate and others where you have to add water in the summer. The Optima has a special design with sprial cells that not only last longer than other lead acid batts. but cannot leak acid and still work even if you shoot them with a gun!!
You can roll over a Jeep and the Optima will still work perfectly while upside down! Not enough? Try leaving a regular Die Hard or whatever sitting for a few months then go try to start your car. DEAD of course. The Optima is famous for being able to start a vehcle that has been sitting around for up to a year and will still turn over the engine. Unless people are cheap asses, (many are) and won't pay the extra money for a battery you can trust, there is no reason not to buy Optima IMHO.
Old Jun 5, 2006 | 10:23 PM
BeachZ's Avatar
Originally Posted by ChevyGoldfinger
Well, for openers the Optima is a true The Optima has a special design with sprial cells that not only last longer than other lead acid batts. but cannot leak acid and still work even if you shoot them with a gun!!
True story. The POS stock battery in my car leaked acid all over the place after just two years. I Optimized that bitch.
Old Jun 6, 2006 | 12:42 AM
BeachZ's Avatar
Where did you get yours? These covers are out of stock at a bunch of sites.
Old Jun 6, 2006 | 06:54 PM
Dal1as's Avatar
Ditto on the covers. I can't stand the yellow color in my engine bay.
Old Oct 20, 2006 | 10:26 AM
kapedogg's Avatar
what's the difference between the yellow and the red top optima?
Old Oct 20, 2006 | 03:47 PM
Yellow tops are for deep cycle needs. (playing stereos a long time without the engine running) Vehicles like boats, motorhomes, etc. that need to run their batteries clost to competely dead at times, and then charge them all the way back up. (thus being called deep cycle)
The red top is for normal use in cars that just need short cycles of high amperage to start, and rarely if ever get drained completely dead or even close to it. That type of deep cycle will shorten the life of a red top Optima.
Old Oct 20, 2006 | 03:55 PM
kapedogg's Avatar
Thanks man, I appreciate it. I think my duralast is on its last leg, and optima is the way to go. I don't usually draw too much extra current while its off for extended time periods, so red top here I come.
Old Oct 22, 2006 | 10:09 PM
Yea 75/25 75/35 are the same it took my sears an hour to figure this out what a pain you know lol
Great battery I have 2 or 3 of these.
Old Oct 23, 2006 | 06:09 PM
76LS1BIRD's Avatar
Restricted User
I have 1 from 1996 and its still going.
10 years old
Dale
Old Mar 18, 2008 | 07:04 PM
Jimmyz's Avatar
OLDIE...where did y'all buy these from? Pep Boys, AutoZone, who sells the red top 75/25?
