Sponsored by: CARiD
check engine code
Old Mar 20, 2008 | 09:56 PM
SmokinU's Avatar
Default check engine code
Hello all,
So my check engine light came on so I went ahead and purchased a reader from local parts store and this is what it returned.
P0440 Evaporative Emission Control System Malfunction
Ok so now what lol what is this code really stating to me. Sorry I am a moron when it comes to these things. I did read the forum on the engine codes and it listed what the codes were jsut like my tool did but for someone like me it dont really say much lol.
Thanks for any help
Old Mar 20, 2008 | 10:01 PM
1Loudz28's Avatar
check your gas cap, make sure its on tight. rest the pcm, and see if it comes back on.
Old Mar 20, 2008 | 10:12 PM
SmokinU's Avatar
Yeah that was the very first thing I did check was the gas cap and it was very secure. I also have not gotten gas in a week so it has to be something else.
Old Mar 20, 2008 | 10:18 PM
ghardester's Avatar
Originally Posted by SmokinU
Hello all,
Thanks for any help
I had a V-6 Bird that had a bad problem with lighting this code whenever the gas cap wasn't put on tight. The first time I brought it to a shop the guy told me it was a common problem on many cars and charged me $50 for renting his code reader and told me to buy one myself. There is nothing wrong with your car, nor will it run bad, light on or off. If it does, then you need to look for a problem.
Old Mar 20, 2008 | 10:37 PM
SmokinU's Avatar
Perhaps it could be the type of gas cap that I have because there is no tightening that you can do to it. You turn it and it clicks then past that point it will just keep clicking.
Old Mar 21, 2008 | 09:02 AM
Luder[PAK9]'s Avatar
That's how my stock cap works.
Old Mar 22, 2008 | 09:37 PM
TxDad-97SS's Avatar
Some time even if the cap is tight the seal around the cap may be bad try replaceing it with a new one from the dealer, have the light reset, if it come back on the have someone preform a smoke leak test to find the leak
Old Mar 23, 2008 | 04:44 PM
VIP1's Avatar
Copy & Paste Moderator
There may be nothing wrong with the gas cap. The problem may actually be in the EVAP system itself. You can try another gas cap first to see if that fixes it. If not, then start looking into the EVAP system.
