Sponsored by: CARiD
where's the drl fuse?
Old Mar 23, 2008 | 02:37 PM
brundz's Avatar
Default where's the drl fuse?
my panels are missing so i have no guide to tell me what fuse is what. any help much appreciated. my front blinkers dont work and i have no drl's so i'm assuming the drl fuse is blown. its a 2000 t/a for reference. thanks guys
Old Mar 23, 2008 | 03:36 PM
Daredevil_TA's Avatar
did you check the manual? i can't remember if it has anything in there or not, or you could just pull fuses untill you find a blown one.
Old Mar 23, 2008 | 03:44 PM
2001NBMZ28's Avatar
Should be in the main fuse box inside the car and labeled.
brundz's Avatar
no manual either. . . thanks alot dealership. i was hopin to avoid the pulling all the fuses until i find it game
Old Mar 23, 2008 | 03:47 PM
2001NBMZ28's Avatar
http://shbox.com/pdf/manuals.html
Old Mar 23, 2008 | 03:48 PM
brundz's Avatar
i have that panel but i didn't see anything about drl's. just turn signals and that fuse is fine . . . i hope this isn't going to be a bigger problem. maybe i have the wrong bulbs in there. i'm assuming the drl is the bright filament in the bulb and so is the blinker so it would make sense for them to both not work is the it was the wrong bulb. i have 3157's in there tho and i thought that was correct. i know its suppose to be 3457's but no parts stores have them and i was under the impression the 31's were the same thing
Old Mar 23, 2008 | 03:49 PM
brundz's Avatar
wow sweet website for the manuals. thanks alot
Old Mar 24, 2008 | 02:07 AM
mtxfrk2k1's Avatar
had the same problem.. make sure the back tail light is working.. the sockets are good and not corroded...
