Alternator Installation?
here is the tensioner!
for the wiring - it is located on the top of the alternator. Just make sure it is unplugged before you try to remove the alternator. It is very fragile.
lets see if ive got this
1 Remove battery
2: Remove belt by loosening tensioner
3: Get under car to the alternator and loosen the bolts enough so i can get to the wiring harness, which i will unplug along with the cable running from teh battery to the alternator.
4: Reverse the process?
Thanks for the help fellas, and please feel free to point out any errors in my order of operations!
1 Remove battery
The yellow arrows show the 3 bolts on the backet. 2 of the 3 are the same size. The blue arrow point to the back side where the bolt holding in the ground wire is. The picture doesn't show the electrical connection that you must unplug, but as I said its near the top.
