Sponsored by: CARiD
Low oil light staying on
Old Apr 5, 2008 | 10:37 AM
z28_YOU_HO's Avatar
Default Low oil light staying on
My low oil light is staying on but i checked the oil and its completely full LOL...why would it be staying on..I just did a oil change about 30 miles ago.. switched over to synthetic running a 5w30 M1
Old Apr 5, 2008 | 11:05 AM
Martin HD-28's Avatar
Sometimes you have to reset the oil light, do a search on here for it. It's done by turning the key on for 3 seconds and something, something, something. I don't remember but you should be able to find it in here.
Old Apr 5, 2008 | 11:07 AM
2001NBMZ28's Avatar
The low oil light comes on when it's about 2 quarts low. After seeing the proper level it should turn off on the second ignition cycle the PCM sees 194*? If it's staying on something is wrong with the sensor or wiring, it's on the side of the oil pan. Low Oil and Change Oil are different things.
Old Apr 5, 2008 | 12:00 PM
gallardo259's Avatar
i have the same problem with my lt-1. i over filled it once, and now the low oil light stays on. if i turn the key to the on position until the ignition/seatbelt beeping stops then turn the key off and then start the engine, the light goes off, but the next day the light comes back on. i'm guessing the sensor is worn or something.
Old Apr 5, 2008 | 12:29 PM
z28_YOU_HO's Avatar
alright so i should worry about it right?
Old Apr 5, 2008 | 12:43 PM
conde'strans's Avatar
If you know the oil level is alright and no leaks no nothin you got nothing to worry about! It also comes on in my car whenever I use the alarm to remote start it.
Old Apr 5, 2008 | 01:12 PM
blkbird's Avatar
Mine stays on all the time. Mine is because of wiring i believe. I always check my oil and its good. Gonna figure it out one of these days. I dont think you should worry.
Old Apr 17, 2008 | 08:44 AM
DaytonaTA's Avatar
Mine stayed on all the time too, until this morning when the car wouldn't start and I replaced the battery. Having the battery disconnected made the light turn off. I just bought a new oil level sender that I haven't installed yet. If the light doesn't come back on, I might have one for sale.
Tom
Old Apr 17, 2008 | 04:03 PM
keliente's Avatar
I think you should worry.
It's a $10 part, if it's bad, replace it. You never know when something freakish might happen, and you'll wish you had fixed it instead of replacing a $3,000 engine.
Old Apr 18, 2008 | 09:37 PM
98boxer's Avatar
the low oil sensor is an engine life saver, make sure to get it fixed and don't leave it unplugged, when my light came on i filled it with just a little over or less then 2 quarts and as soon as i put in the oil to the right level the light went off diffently check the wires or test sensor
Old May 7, 2008 | 05:37 PM
blkbird's Avatar
Finally figured why mine always stays on, the brown wire was broke right outside the connector and you cant tell cuz its still intact, just the wire stretched and broke somehow....
Old May 8, 2008 | 12:22 PM
Vega's Avatar
I had the same exact problem occur to me 2 months ago. I would check the oil level and fill it but it would still come on frequently. Eventually, I just figure it was a bad sensor so I ignore. However, when the oil does get low it wont warn me or anything so I have to check the level periodically, I guess the sensor died. It kind of sucks thou cause my car eats up about a quart of oil between oil changes. Hopefully when I seafoam the engine something magical will happen in reducing oil consumption.
Old May 9, 2008 | 10:26 AM
mcflyz28's Avatar
if you have headers check the wiring mine was caught in between the starter and header on the passenger side.
Old May 16, 2008 | 10:29 PM
blkbird's Avatar
Just replaced the connector and no more light!!! The connector cost me $12 shipped and i soldered it in and put some heat shrink on it. Good as new!!
