Sponsored by: CARiD
98 ignition lock problem
Old Apr 15, 2008 | 04:27 PM
enos44's Avatar
Default 98 ignition lock problem
My dad has a 98 chevy pickup and when you put the key in the ignition it is sometimes nearly impossible to turn it to start the car, any ideas on what is wrong? the truck does have 160,000 miles on it so it could just be worn out i suppose. thanks
Old Apr 16, 2008 | 08:23 AM
wssix99's Avatar
Save the manuals!
The key is probably worn out. If you go to a dealer and give them the VIN, they should be able to punch a new key that will fit the cylinder perfectly. (Just copying your worn key won't fix the problem.)
Do you have a spare key to try?
Old Apr 16, 2008 | 07:14 PM
enos44's Avatar
that was exactly the problem luckily we had a spare key and it works perfect thanks!
