Sponsored by: CARiD
damn blinkers please help =\
Old Apr 29, 2008 | 07:26 PM
NavyBlue01's Avatar
Default damn blinkers please help =\
okay guys i have been throgh 3 sets of front blinkers on my 2001 camaro in the past few years by blinkers i mean the housings.. they fog up and blow the bulbs really bad and the actual housing melts and busts and gets deformed i see this alot on f bodys is there a fix for it?
Old Apr 30, 2008 | 06:04 AM
jkichline's Avatar
The only thing I can think of is to try a lower wattage bulb. I have seen a lot of mis-engineered lighting housings on a lot of vehicles. The ones I notice most are the chevy suvs with DRLs.
The heat from the bulb your vehicle calls for is too much for the housing. Try lowering the wattage by about 10-20%.
Old Apr 30, 2008 | 07:24 AM
NavyBlue01's Avatar
i am using silverstar blinkers i think they are already a lower wattage =\
Old Apr 30, 2008 | 08:14 AM
02BEAST's Avatar
Did you check your blinker fluid?
Old Apr 30, 2008 | 09:01 AM
LastHawk's Avatar
I'm about ready to say screw the DRL's and somehow making them strictly turn signals...
It's quite ridiculous...
Old Apr 30, 2008 | 09:32 AM
bene's Avatar
Trunion King
Drill small hole(s) on the bottom of the blinker. Make sure the hole is away from where the bulb is sitting.
Old Apr 30, 2008 | 09:35 AM
LS1crazy01's Avatar
I thought about this too. Do you think it will work? I was worried about more water getting in there. But I guess it would have a way to get out then.
Old Apr 30, 2008 | 09:45 AM
vx15i's Avatar
Use LEDs. You have to get a LED flasher also.
Old Apr 30, 2008 | 12:13 PM
LS1crazy01's Avatar
How do you convert it to LED?
Old Apr 30, 2008 | 12:17 PM
camrossrs99's Avatar
drilling a small hole works. i had the same problom on my 98. what it is the seal on top of the blinker doesnt seal tight enough water gets threw there gets on the hot bulb and blows up. if the hole is drilled it has a place for water to exscape.
Old Apr 30, 2008 | 12:21 PM
vx15i's Avatar
I sent you a PM with links.
Old Apr 30, 2008 | 12:23 PM
LS1crazy01's Avatar
Thank you I really appreciate it.
