How do I test a coil pack?
I didn't know anything was wrong with it until it went on the dyno at G-Force. It "banged out" above 3500 RPMs. We checked the plugs and replaced the wires to no avail. I've checked the plugs again since then. There are no DTCs because G-Force deleted the misfire tables (Why they did that while they new I was having a misfire problem, I will never know). So I have nothing to go off of except that I know its getting worse, and seems to be worse when the engine is hot. It was unnoticable during regular driving, now it shudders in 6th gear, or at low RPMs in general. It's also causing exhaust backfires even at idle. All the fuses and plugs have been checked. My eyes are on the coil packs because they're 213k miles old.
How do I test a coil pack off the car? I can't swap it to another cylinder, because I don't have misfire tables to read. G-force is 3 hours away, or else I'd just have them restore the tables. I tried search, didn't find anything. I'd rather not have to drop the dough to buy ALL the coils.
one way you can test them is measure the impediance on the coil, should be something like 0.5 to 1 ohm, but this only tells you if the thing is good or bad. The coil on the running hot engine is a completely different environment and if you don't focus on that you are wasting your time. heat is bad for a coil and can make them fail intermittently, until they cool off. unfortunately the only real good way to check is with a full blown diagnostic monitoring ignition on every cylinder with a scope, and waveform charts will show injector pulse widths, coil firing and all that **** and you can pinpoint the problem instead of throwing parts and money at it.
What you might try is get a DTC and find out which bank it's on, then swap the coil packs from left to right and see if the DTC moves over to the other bank.
this is assuming you have good plugs and wires and your plug gaps are good.
