Sponsored by: CARiD
Light problem
Old May 16, 2008 | 12:43 AM
TBONE2002's Avatar
Default Light problem
Alright guys i need help with my lights. The headlights and the dash lights flicker constantly on my car. It is like they are constantly getting power surges. I cannot figure out why. Any suggestions would be greatly appreciated.
Old May 16, 2008 | 01:18 AM
NBM-LS1's Avatar
Check the connections. In the fuse panel on the dash.
Old May 16, 2008 | 01:52 AM
sixvi6-camaro's Avatar
Search.. search.. search...
https://ls1tech.com/forums/showthrea...hlight=flicker
Bottom line... you need a new alternator.
Old May 16, 2008 | 02:01 AM
TBONE2002's Avatar
Default lisghts
Thanks guys.. I thought that was it and had it tested today.. Of coarse it tested fine..I will go ahead and replace it though. I appreciate the help.
Old May 16, 2008 | 08:37 AM
Shake's Avatar
T-Bone:
I have the exact same problem on my less-than-1-week-old toy ('99Z). I took it to AZ last night and had them test the alternator online. Needless to say it isn't putting out the amps it needs to.
Also, I believe that the voltage regulator is built into the alternator for the LS1 F-body. If that is the case, then your alternator could be putting out solid amps, but the voltage is fluctuating....thus causing flicker in the lights.
At a stand still, rev your engine up & down....watch the volts gauge....it's probably dancing a bit.
Old May 16, 2008 | 10:59 AM
98FreakZ's Avatar
Alternator FTL
Old May 16, 2008 | 11:47 PM
Shake's Avatar
FYI...did it tonight. Took me about 2.5 hours alone to change the alternator & both belts. That includes getting the car on & off the jacks.
The wires cannot be disconnected until you have all the bolts out. It helped me to let it rest on the sway bar after unbolting it.
