Oil is Always Black
Also last weekend when I took off my valve covers it was blacker than black in there and there was all kinds of black chunks (carbon?) everywhere...Im talking big *** crusty chunks stuck to the inside of the valve cover.
You need to seafoam it again. Make sure to add seafoam into the oil. Change the oil after 150 miles of the seafoam being in there.
Also seafoam throw the PCV to clean out the top of the engine.
If you are really worried, do a used oil analysis to see what's up.
I bought my son a V6 Firebird with 85k. It had had a fresh oil change. Oil was black when I checked it at 1k. This is abnormal.
I had a BG oil system clean and flush done. It improved the situation but the oil is still getting dirty faster than normal. I'm going to have him use one of the "high mileage" oil brands. That will continue to clean it till it gets to normal.
I'd do a compression and leakdown test to gauge the condition of the engine.
I recently got a neglected 81,000 mile LS1 and it's oil gets dirty quick, it's got flaking brown crap in the valve covers.
You have to remember that stuff is stuck to every internal part if the engine that doesn't move and thats causing the oil to get black.
What I might do some day is take the valve covers off, manually clean them, take a can of seafoam deep creep or something and spray the tops of the heads, rockers, etc. Let it run through the pan and drain out.
Then when it comes out clean maybe put the plug in and pour a can of seafoam in and let it sit in the pan to dissolve any chunks and clean the oil pick up screen, drain it, maybe repeat until it comes out clean. Then put new oil in and idle it for a short time, drain it, put new oil in and be done.
The only other option is to take the pan off, or just run it and don't worry.
