Hyperlube?
Anyone ever use Hyperlube oil supplement?
For high performance and high mileage engines. Completely blends with all petroleum and synthetic based oils and will not breakdown or foam out.
Hy-Per Lube is proud to make the following promises:
- Increased fuel efficiency
- Increased horsepower and torque
- Complete cold start protection
- Cooler lubricating temperatures for hot weather, towing, racing and under heavy load conditions.
- Reduced oil consumption
- Frees sticky valve lifters
- Improved oil pressure
- Maximized or restored compression
- Significantly longer equipment life
- Effectively cushions drive train shock and reduces noise
- Smoother shifting
- Leaves protective film on all internal parts even after shut down providing instant lubrication on cold start-up (where 60-80% of engine wear occurs)
- Reduced oil and fluid foaming
- Blends with all petroleum-based engine/gear oils and synthetic oils.
I have tried it and its good stuff. Motor seems to pull a tad harder especially in the mid to upper rpms.
In stead of having to wait for an oil reading to let, the oil settle in the pan it give you an accurate reading right away. Thus it "clings" to oil and engine parts.
I can see why this stuff is perfect for "cold" starts. Oil all drains back down into the pan, where this leaves a tiny film on the engine parts. I've got it on my hands before so I can vouch for it.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
