Sponsored by: CARiD
A/C Leak Repair Question
Old Jun 18, 2008 | 08:28 PM
UAZ28SS's Avatar
Question A/C Leak Repair Question
So my a/c has been down, with the compressor not running, so I finally got around to testing it. Discovered that the system has a leak which is located on the bottom of the aluminum piping coming off the evaporator canister. The low system pressure triggered the pressure switch, in turn causing the compressor to not run for self-preservation purposes.
Here's my question: Can I patch the small hole with JB Weld (yes, I know... backwoods and cheap) for the time being? The stuff claims to adhere to aluminum on objects that have a decent amount of expansion and contraction, so I figure why not try until I feel like coughing up the excessive ton of coin necessary to fully repair the system. Any thought or advice would be greatly appreciated, as I'm taking the car on a couple trips to rather HOT places the first part of July and I NEED the a/c!
Thanks in advance!!
Old Jun 18, 2008 | 08:45 PM
AKAFRED's Avatar
go the wreaking yard and get a used hose.. jb weld isnt probably rated to 300+psi
also by the time you pay to evacuate and recharge the system your going to want to only do it once..
Old Jun 18, 2008 | 09:13 PM
BigZee71's Avatar
DO it right or do it over.
But yeah, if your set on using JB weld, prep the area but sanding it down the cleaning it.
Make sure you pull a vacume for at least 45 min. and make sure it holds vacume for another 25 min afterwards.
Also keep inmind that aluminum will expand and contract as it is heated and cooled wich will in time possibly cause the JB weld to beak loose or crack itself.
Josh
Old Jun 18, 2008 | 10:15 PM
9000th01ss's Avatar
NO!
They make epoxy for residential AC repairs and it's only used on aluminum tube (since it can't be welded). This stuff is WAY stronger than JB Weld and the longest I've ever seen it last was about three days. And it's still intended to be a temp fix.
Old Jun 19, 2008 | 12:58 AM
UAZ28SS's Avatar
Well, I decided against the JB Weld. Too ghetto and too risky, as it's only VERY temporary.
Old Jun 19, 2008 | 10:05 PM
Crimson's Avatar
Josh
A vacuum for 25 minutes is only 15 psia. If you're going to do it right put 150 pisg in the line and see how it holds over a period of 1 hour at least
Old Jun 19, 2008 | 11:01 PM
9000th01ss's Avatar
You don't use vacuum to check for leak unless you have a micron gauge to measure it. Most people asking if they can JB Weld a refrigerant line do not have a micron gauge. No offense to anyone.
Old Jun 21, 2008 | 03:04 PM
Crimson's Avatar
I don't know what I was thinking when I said a vacuum is 15 psia. Never mind that.
What I meant to say was the best proper way of checking a system is to 150psig of dry Nitrogen gas in it and let it sit for an hour. If you can't do this, do not put compressed air from an air compressor in the system you'll just be putting mositure in the lines
