Just changed oil, Huge oil pressure improvement!
Old 10-28-2008, 10:10 PM
SSickLS1's Avatar
Originally Posted by 98boxer
Also I use to have to put in 1 quart of oil every 2 weeks with other oils till i switched to Valvoline now i only put in 1 quart every month if not a little more then a 1 month. All ls1's burn oil.
Neither of mine do - a quart every 2 weeks? WOW:
Old 10-28-2008, 10:15 PM
SSickLS1's Avatar
Thumbs up
Originally Posted by CranMaro99
I have a 99 and it idles warm at 40psi. I must be lucky
That makes 2 of us - BTW beautiful Camaro (im partial to the color). Its always nice to see a metallic blue w/ less than 50 grand on it, rare indeed esp w/the rs kit.
Old 10-29-2008, 03:10 AM
99Ws6302's Avatar
My 99 TA Warm never goes below 40 no matter how hot, runs between 60/70 cruising and driving. 5w30
Old 10-30-2008, 02:27 AM
98boxer's Avatar
Sounds like bs, but at the time and for awhile after that i ran my car fast. Don't know why but switching to valvoline helped to burn less oil. I know most people here put at least 1 quart of oil a month. If your a daily driver and not grandma driving.
Old 10-30-2008, 03:00 AM
myk
myk's Avatar
I must be lucky, then. I don't have to add oil between changes, which I do around 7500 miles, and I'm running Mobil's 0W-30.
And yes, this car is driven daily...
Old 10-30-2008, 03:07 AM
Joshiedoom's Avatar
153666.totally original. Not a drop of oil burnt.
PP 10w30 with k and n ilter... cold is 50 psi.
hot is 35.
Old 10-30-2008, 04:17 AM
myk
myk's Avatar
Well, ALL engines burn away some amount of oil, but by the quart? WTF is that all about...
Old 11-01-2008, 09:22 PM
TORCHD 02 TA's Avatar
Remember i have a LS6 Ported and Shimed Oil Pump. I also run M1 Syn 5W30 and M1 Oil Filter.
But on a cold start mine is at about 60 - 62 psi, while crusing ~50 WOT almost 78
