Oxygen Sensors
Thanks in advance!
Thank you so much!!
What is it that they do that gives them such a bad rep?
interesting....ill go do that now.
Thousands of members here use them. As do I. They are just like any other car part. All it takes is one or 2 people to get a bad part and all of a sudden, that part is crap....The reality is, they perform well. Take your chances
1. The front 2 are a pain in the butt and will probably take a cheater bar or breaker bar to help.
2. The back 2 were not any easier.
The tools I used were an 18"x1.5 tap that I got from NAPA(i'm sure you will need this if you have factory 02's)
I bought a socket that has a slot in it from 0'reilly's (I asked for an 02 socket tool and they knew what I was talking about) that helps with not having to cut the wire on the old one in the event you need to use your car and can't get it off yet. I cut the sheathing around the wires but not the wires on the old 02s when I did mine so I could get my socket around the 02. I got anti-seize as well. It took me about 3 hours sometimes per 02 as mine were super welded together and I had to retap every thread to each 02 after removing. I used the 18" tap,a socket that fit the back of this, and a racket. I went slow and was able to rethread all just fine and the new ones threaded right in. If you get the 111's for the front I suggest zip tying them up for when you get your lt's,if you do, and keep it from being snagged. Hope this helps ,feel free to message me if you need pictures of the tools I used as well. Here are some links to what my threads looked like after removal:
http://www.fquick.com/garages/viewga...wimg&id=159480
http://www.fquick.com/garages/viewga...wimg&id=159481
Thanks! ill stay in touch
