Mobil 1 Question
jON
As far as changing the oil filter at 2,000 that would be a waste of money. The Mobil filters have worked effectively in my cars for over 4,000miles. At $11and up a piece you'd be throwing more money away like that.If you wanted to use extended drain intervals I would suggest you fill up with synth oil and use the mobil 1(or equivalent) filter.Change the filter only every 3-4k miles and then do a complete oil/filter change every 9-12k miles.That is what a Redline oil rep suggested I do. I personally just change oil and filter at 3-4k miles.
On a side note, I use Mobile 1 myself and I think it's a good oil.
lerajie -- Why don't you use mobile 1 anymore?
Mobil 1 is good oil, but too thin for the LS1, unless you mix 2qts of 15w50 with it. A much better choice would be Redline or Amsoil, both of which are thicker oils with better HTHS numbers (for better bearing protection under hard usage)
Anyways, back to Royal Purple. I'm going to be switching my wife's car over to their 10w30 in a couple of months. I want to see if it thins out as easily as their 5w30 does.
So if you do run Royal Purple, don't run their 5w30, run their 10w30 or even their 10w40.
The LS1 engine tends to show it's best wear numbers when using a slightly thicker oil, like Amsoil's 5w30 or Redline 5w30. This new German 0w30 is also thicker than most 30wt oils too, like Amsoil and Redline, it's almost a 40wt oil. Mobil 1 on the other hand, is on the very thin side of the 30wt range. Which is why if you're stuck on using M1, you need to mix in a quart or two of 15w50 to beef it up.
I pulled the valve covers on the SBC in my Chevelle to run the valves.There was a noticable amount of "gunk".I had only used two oils in this engine since I built it.Havoline for the first 2k miles and then Mobil 1 for about 9k.I started using Redline in that engine and pulled the covers to run the valves and there was none of the deposits I had seen before.My conclusion that Redline is better than Mobil could be based as much on perception as fact when it comes to these events but it was enough for me to stop using Mobil 1 and switch to Redline.Besides that I was impressed with the technical data I have seen on Redline and by the people who know alot more than I do choosing to use it.
Redline seems to put more money into their product than they do marketing which I appreciate.Companies like Castrol seem to do the exact opposite.
Did you guys know Mobil sued Castrol for calling their "synthetic" oils synthetic when they are technically just reformulated dino oil?
As far as the Castrol thing, it's true, their Syntec lineup is hydrocracked petroleum, not a true synthetic, however the one exception is that German made 0w30, which is a true synthetic. In Europe they aren't allowed to label an oil as synthetic if it's using the group 3 hydrocracked base oil. Only in North America have they allowed this type of deception to occur.
On a side note, Patman, why exactly is the Mobil 1 too thin for the LS1? Not trying to doubt you, just trying to understand how certain oils are matched to certain engines and conditions on a more scientific note instead of the old, "that there sounds perdy good" way.
Other good flowing filters are the NAPA Gold/Wix filters, and the Amsoil ones. Walmart Supertech is also pretty good, it's made by the same people that make the K&N, and it's actually an STP oil filter.
As far as Mobil 1 and the LS1, if you look at the specs on Mobil 1, it's viscosity at 100C (which is the typical operating temperature of your oil) is only 10cst at 100c. In order for an oil to be a 0w30, 5w30 or 10w30 oil, it's viscosity at 100c must be between 9.3cst to 12.5 cst. As you can see, M1 is formulated on the very thin end of that range. This works very well for the tighter clearance engines out there, which is the majority of new cars. But for the LS1 and LT1, and most American V8s and V6s, they are typically built with looser clearances, so it helps if they run an oil that is formulated a bit thicker, closer to 12cst will work much better. As an engine puts on more mileage, it's clearances also open up slightly, so the need for thicker oils becomes greater. This is why the high mileage oils work so well for many people, because they are typically formulated on the higher end of their viscosity range.
As far as what viscosity an engine likes, it's basically a general estimate I'm giving, based on my observations on various oil analysis results. Of course it could be slightly different for each particular person, depending on their driving style and climate too. Oil temperature also plays a big part of it, as someone who road races and sees consistently higher oil temps would want to run an even thicker oil, unless they install an oil cooler.
The best advice I can give someone who wants to choose an oil is to get an oil analysis done on your oil after you've put 3 to 5k on it. See how the wear numbers look and then if you don't like them, try something different.
www.blackstone-labs.com
If any of you guys decide to get your oil analyzed, post the results on here so we can look them over.
