bosch triple platinum spark plugs?
I recently put some venom 30 pound injectors and i also installed some bosch triple platinum spark plugs and when i started it it hesistated to start then it starts popin but after it warms up it stops i have a 2002 camaro ss 35th anny. with a comp cam k&n intake 80 mm throttle bodie edelbrock shortie headers, muffler delete and a custom tune u guyz think I should put some a c delco iridium spark plugs in is it some thing else my car never had no problem startin up with the stock plugs
LS1TECH & Trucks Sponsor
Was it tuned AFTER the injectors?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
NGK TR 55's all the way.
BOSCH AND GM DO NOT MIX ive had them in my 5.3 and it caused misfire in #1 and #8 i also put them in my 01 ls1 it caued a bad stumble along with a nasty misfire at idle put them in my 98 gt 4.6 it runs great no problems for about six months and thats the god honest truth i would recomend NGK TTT i think thats the model plugs that i use i in my
LS1 with 32# injectors ls6 intake LT's and afr ram air lid and 228 232 cam
i actually put the plugs and the injectors at the same time i was gonna get it tuned right after but then it startin with the misfires and trouble starting
You can't change injectors and drive it without a tune.
__________________
