3rd gen wheel in 4th gen
Problem is... it is rubbing up against the column. Has anyone else done this? Curious as to what adapter I might need or if I will just need to dremel down the column.
Like I said though, has a few bugs to work out...
So do you have to deal with the airbag light on all the time now?
You should see how much easier you can see the gauges now too though
The airbag light is pretty simple to fix.... Going to pop the led off the board
