Window doesnt't go up all the way...Pics included
#41
mine does the same thing. only it started when i had the window replaced. due to punk *** kids running around shooting out windows. now im gonna tack a look and see if i can fix it.
#43
yeah lets bring this thread back.. i've been having the same problem for months now and I've just been dealing with it but i'd like to get it fixed. I'm actually on my way to MA (350 mile drive) to get a new door b/c im so sick of this problem. How much did the body shop charge to do that work?
#46
i am having that same problem with my window. That idea doesn't sound to bad plus with some adhesive if the motor ever goes out again you can just remove the plate with the motor bolted in. keep me informed on how it works out for you.
#47
This thread is an oldie but goodie... i recently bought my 99 and was told by the previous owner that the motor was bad.. i just got around to fixing it today and found that the tracks were gone, motor was gone and it was held up by fukin clothes hanger wire... not to mention the damn thing was all drilled to ****... i fukin hate morons who do **** all ghetto.... i will probably just do the metal plate and be done with it. does anyone know where i can find a diagram of what the door is supposed to look like, and the small track im missing, its the one on the very bottom of the drivers door that the rear/lower regulator wheel rides in.
#48
Save the manuals!
#49
i found it on here... just had to use better key words... i found a very good writeup with pics on here. Im scared to death to take the other door apart.. hell, every time i fix something on this damn money pic i see another damn bullshit repair... its like they put it together with duct tape and bubble gum just to get it to sell... so far:
#50
Camaro Driver door
Looks like to me that teh Camaro has a defect in the door. 1) it's fiberglass holding a stree point, 2) my camaro also did the exact sam thing without user intervention.
#51
Save the manuals!
Can you post a pick of your panel and those rivets?
#52
I've had the window gap issue for a month on the drivers side door at 23k miles; just took the door apart to find the fiberglass being torn up. The issue started from screws holding the power window motor in place falling out, putting more force on the holes still holding a screw. Well at least I know the driver side motor isn't original.
So my options for repair are:
1. Re fiberglass and drill new holes (Either use a rivet with a steel mandrel and an aluminum jacket, or screws/washers/lock-nuts/loctite)
2. Design two metal plates, one for the inner portion of the door and one for the outer portion to take over the shear stresses
3. Clamp it down with fasteners
4. JB Weld washers in the proper location
And my passenger side window motor died recently. I'm having serious issues with window motors lately.
Bottom screw/fiberglass taking all of the force.
The following users liked this post:
magius231 (03-03-2024)
#53
Save the manuals!
#54
So here is a question on this topic... Has anyone made a template for the plate? Any thoughs on the thickness of the plates for each side? Since the original installation is fiberglass, would stainless steel or some other tought metal be adequaate?
#55
I made one about 2 months ago, took me 4 hours.., i made the plate big enough so it would fit in there perfectly and 2 bolts with lock tite went threw the 2 used holes.. and riveted thew the door to the regulator..
#58
I did the sheet metal plate repair yesterday and it is working so far. Pulled the regulator/motor out removed the old rivets and jackets, ran to the hardware store and bought a 12"x24" piece of 1/8" galvanized sheet metal and 4 (1/4" grade 5) bolts that were 3/4" long, 4 locking nuts and 4 washers for a grand total of under $12. Borrowed some tin snips-cut out a piece of metal, clamped it to the fiberglass and drilled holes.
Used the two washers on the outside of the plate for each of the two bolts closest to the door hinge (probably should have gotten 1/2" long bolts but this worked) to keep the bolts from obstructing the path of the regulator gear.
All in all it took me about 2.5 hour to reinstall everything by myself (retracking the rollers alone was a PITA)
#60
Save the manuals!
I'd be really careful doing this. Incorrect rivets or bolts are what usually gets people in to this problem in the first place.
If you go with rivets, you'll need to make sure they are steel mandrel (for strength) with aluminum jackets. (so they don't tear up and stress the composite) As well, you'll need to make sure the rivets don't interfere with the moving regulator parts.
If you use epoxy to fuse the plate to the composite, you can then use anything you want to connect the regulator to the plate since that's metal-on-metal.
